jtackerman28
I just put a new supercharger on my 2003 gtp, I ported the supercharger before i installed it and it also has a 3.5 pulley on it. For other back ground on the car it has a aftermarket down pipe with a highflow cat, a hot ait intake, 103's, and a 180tstat. I also have a scan gauge set up to read knock and the most i have seen on this set up is 2.5* with it about 90* out.
Now to the problem. The car is idling between 1000-1400 rpm in park ad down to 1000 even in gear. I've done a few things since the high idle to include spraying carb cleaner abound every vac line and around the supercharger and throttle body gasket. I also removed and swaped the iac off of a properly running 3.8 and still have the same problem. Also another thing that bothers me is that the evap purge is running like crazy, i also swapped this off the other properly running 3.8.
The only thing that i can think of so far is that there is an extra port on this m90 next to the air inlet at the rear of the supercharger and i capped both of those open ports off.
Any advice is greatly appreciated and would love to not have to take it to a shop :th_nervous:
