supercharger problem
fremmy182
I see my m90 blower has torx screws that connect to the tb. I was about to put my new gen 3 in my car and theres nothing to screw the tb into.. ?? im confused
^^ what he said. FWIW the tool you would ideally have is called an Etorx. It's a reverse torx bit that fits on those.
You can also use the jam nut method where you put two nuts on the stud...first upside down and second on the right way. Tighten the second nut against the first nut by holding the bottom one with a wrench. Then, use the bottom nut like a bolt and remove the stud. Works very well.
That's what I've always done. Works like a champ.
