Sunroof Question
Freddy
My sister has a 2000 grand prix and its a gt. Her sunroof wasnt working so i checked the fuses. it was burned out so i replaced it. i tried it to see if it worked and nothing. so i pulled the fuse again and it was burnt out already. and i tried a bigger fuse cuz sometimes you can get away with that(i know its frowned upon) but it just sparked when i pulled it out. I need to know where to start looking to fix this problem
You shouldn't just replace fuses over and over - they're blowing for a reason.Did the fuse blow before you even touched the switch again? If so you may have a short somewhere.
i just replaced it just the once and im not sure but im guessing so because there was no power to the switch after 2 seconds maybe
