Sunroof leaking / door trim questions
I ordered the part to stop water from entering the passenger side floor. But now I see the sunroof has a leak. http://m.imgur.com/MPMFj3v what steps should I take to fix this?
Also the trim on my drivers side door is letting in a small amount of water. It's the trim on the top outside of the door. What part number would be the trim for a 97 coupe gtp? http://imgur.com/84DdqCG
Don't want to order the wrong parts and have to wait longer to get this beach sealed up. As always thanks for the advice.
When mine leaked it turned out to be a clogged drainage hose. I had to drop the headliner a little to get to it. I could see what was clogging it and just used a screwdriver to push it down and flush it out.
I've been looking for replacement trim for a while now.
I have a 98 2door and the trim on both doors is just crumbling.
Not sure what it's actually called, but It's almost like a V. One side is attached to the top of the door, and the other is free to block water from coming in.
Anyone have any idea where to find some of that?
One thing to check as well, the felt liner in the fenderwell can get clogged and cause water to overflow into passenger floor. Took me forever to figure this out. And for me, the sunroof leak was a drainage hose that came off, soaking my headliner. Turns out they do not secure these lines at all and rely on the weak "barbs" to hold them. I recommend adding hose clamps while you're up there.
