Suggestions while replacing intake gaskets
918GTP
This is only my second post so cut me some slack. I am replacing the intake gasket due to a coolant leak on the rear side of the intake. But I have read alot of post about epoxing ports in the S/C, Porting and such. So with that said is there any suggetions that you folks recommend to do while this stuff is apart. Also any tricks for assembly and a leak proof repair. I am going to use Fel-pro gaskets any word on good or bad with them. Thanks in advance for any suggestion. Heath
get the gm aluminum gaskets from zzp or the dealership, they are better. you can use a felpro blower gasket though. did you read my post on blower porting? i have some pics of epoxy work to get you going.
