Sub Help
Take off the deck cover and fire the subs. Locate the rattle(s), tighten and/or sound deaden necessary locations.
got 8 layers of seal n peal on mine think i'm getting rattle again....
Adding more layers significantly DECREASES any measurable gains. If you don't want rattle...find where the parts are vibrating together and stop it at that point. Resonating panels are different, that's where you throw on a sheet of second skin/seal peal/dynamat(whatever product you want). Covering 25% of the panel lowers 90% of the resonation to a lower frequency. Weight is your friend when killing out resonating panels. Vibrations between two objects is something different though.
I have a feeling there's another purpose for your setup :) I'm just making sure others know!
