Strut mount keeps failing
Silver GTP
When I did my suspension over, I went with Monroe strut mounts since so many people had used them without a problem. After six months, the rear, right mount failed. I wrote it off as bad luck that I got one that failed early and replaced it. Now, three months later it's failing again. I don't want to replace it with another Monroe one. Any recommendations? I am leaning toward getting GM mounts since I have never had to replace a rear in any of the Grand Prix's I've owned. I see rockauto has AC Delco mounts for about $26, but the ones on GMPartsDirect are $61. Any suggestions?
Same here, just what are the symptoms of a failed mount? I'm using Monroe's on the 98 and am putting the same on the 02'.
Mine started as a noise like a rubber bushing that was binding then changed to a clunk that kept getting worse. The clunk would happen going over bumps that were small or large. If I jacked up the back of the car (both sides to make sure the sway bar was not torqued), I could grab the whole strut assembly and yank it up and down to make the clunk noise. Being right next to it, I could clearly here the noise from the top of the strut. I replaced the mount and the noise was gone immediately.
I've had KYBs for ~8K miles. Not pushing them but if the GM mounts aren't in stock then consider KYB mounts. Monroes? Glad I stayed away from them.
My monroes have lasted for three years so far with no issues. I have heard mixed reviews on the KYB's.
monroes are really the only opitions we have. Stock ones are have a design flow and monroes fixes it.. Just the way it is with these cars.
Can you explain this any better. :confused: What is the design flaw and is Monroe the only one to make an improved design? I have found the following brands available for rear strut mounts: Monroe, Mevotech, Raybestos, KYB, MOOG, AC Delco and whatever GM sells. I thought AC Delco would be what the dealer sells, but the price is much different. I respect MOOG's products, but don't think I want to deal with three bolts instead of the mount having three studs. Doing this for the third time now, price of the mount does not matter. A $25 dollar mount is not a savings if I have to replace it every few months.
My own personal experience does not look good for Monroe's. I have had three Grand Prix's and never replaced a stock rear mount for failure. I have had two Monroe's fail in 9 months. Like I said previously, I went with Monroe's due to everybody saying they worked well, but I don't want to see if the third one will finally hold up.
The spindle on the sturts that slide up into the mounts. Well to keep it centerd. There a couple nipples is different spots that touch the sturt spots. Thats what was causing mine to clunk.
The monroes have a sleeve that slides over the spindle so the entire spindle is secure inside the mount.
Thats atleast that what I noticed that was a better design then stock. You I guess just have bad luck and I was would be pissed too changing them twice in the 9 months. The rears are a *****...
