Could be the strut mount bearing, cv axle, or a number of suspension parts. One way of diagnosing is to put your hand on the strut mount when someone is turning the wheels and feel for popping or clicking. This isn't a definitive death knoll on the strut mounts since a number of vibrations can transfer up through the mount. Usually if you can repeat this on the same strut off the ground too, it's the mount. Next you can raise the vehicle and feel for play with the wheel locked on both tires. If so, it's not your strut mount unless it's about to come off. Feel for excessive play on the cv joints, ball joints, control arm bushings, end links, and tie rods. If anything is loose, that's most likely your noise. I had something similar and it ended up being cv axles that I just replaced with brand new ones that were bad from the start, go figure!
Also, it's not a bad idea to lube up bushings like sway bar and end links. Good luck!
