Strut choice for lowering springs
kking89
what kind of struts do you guys think i should get? I have ebiach lower springs. its supposed to be 1.5-1.7 inch drop. I was thinking about getting KYB AGX struts from Rockauto.com. Its about 150-170 for each end set. Also do you guys think i will rub when i lower my car? i have 18 inch wheels on 245/45 tires
cant exactly remember. i think its 35 maybe 36mm offset. they are 18x8 sport edition wheels. Look very similar to the Kv5, but they no longer make my wheels. I dont remember the name of the wheels :(
I'm running 18x9.5 with 245/45/18's 28mm offset on SSC lowering springs, and I've got a little room to spare. Should be plenty fine running the same size wheels/tires with the 35mm offset
04s tend to drop a bit more then the previous gen Squid!
It's simple anyways.. Heat gun, mallet or wooden back and a hour of your time.
i got a 03. yah i know i could roll my fenders. my brother had just done it he may still have the roller the hooks on to your wheel hub. but i would rather not want to cuz with my luck i would crack the fender.
yah i plan to get AGX, with some anti pogo bushings. anything else you recommend to make the ride better?
Go to partsgeek.com for the AGX struts. $445 SHIPPED. and here is a $15 coupon code for an extra discount(SAVE15). your welcome :)
Rockauto has them listed for 110 per front strut, and 120 for each rear. Plus shipping.
dont buy the GR2s. They are garbage.
they don't have ANYTHING adjustable for height. even a knob on a coilover like that wouldn't adjust height. height is adjusted by moving the springs OR the strut body, NEVER the knobs.
it's rebound/compression damping adjustment.
and yes, GR2 are cheaper. they're a stock replacement strut.
