GTP Push
The issue I'm dealing with is on my dd 98 gtp (high flow cat, magnaflow catback, poly upper mounts 180 t stat, and hai). Car has 173k and a new transmission. When in gear, stopped at idle, the car has what feels like a miss, but throws no codes and it clears up as soon as throttle is applied. In park the rpm rises to approx 900 and the tremble lightens but is still present. The rpm is steady as normal idle would be, but once in a while it'll drop when coasting at round 20-45, from 1200 down to bout 800-900, then come right back up. The stock boost meter also shows that it isn't making full boost until 4800 or higher (started after pcv was replaced). It has new plugs and wires, new pressure regulator, new pcv valve, changed sc oil, Mobil 1 oil. I'm curious as to what anyone might think the issue is. I'm back and forth between bbv, injector(s), or hand of god twisting my brain. Lemme know what you think or if you need any clarifying.
