Stock Torque motor Mount Does not match new one? Different design
CheeWee
I went to purchase the Motor/Trans Torque mount and it has this design...
PartsTrain.com - Hard to Find Auto Parts and Truck Parts -
The one i currently have does not have the Hook it is a C design. have any of you guys had this problem before?
Thanks
Looks like it is missing the bottom half...I'd just return it and go to a junkyard and then buy poly inserts. Done.
Yeah and it all the other parts stores Have the same design too. Witch it will fit but I am not sure how it will hold up...
Might just have to go to junk yard...
You can use them, they will work fine. There are already holes in the radiator support so you can put the bolts in on the front part of the mount. I went through the same thing, all I can think of is that they are a newer design or used on a different w-body. Had mine for a while with rotated mounts and they are holding up fine.
