I was thinking it was 3.5". I can take a measurement for you with my calipers when I get home if no one comes up with an answer before then.
I believe that happened when the fans kicked on and filled the engine bay with 186* hot air from the radiator.
Didn't the WizAired come with a "sleeve" for the TB to make it 4"? Mine did, which is required since the WizAired's tubing is 4".
Ive put a 3.5" coupling on there before. But you are right, it takes some shoe horning to make it work.
Yeah and that also caused my FWI to slip right of when motor movement occured...im guessing because of the ''lip'' on the tb not being there any more. removed it and it was fine.
