steering rack upgrades
the turbo regal is an FE3 rpo 00 regal GS
steering rack is 2.5 lock to lock
we just upgraded it to the GXP/CompG rack (04-06) and it is 2.25 turns lock to lock
figured id post this for others
According to what I can find out, the total end-to-end length of the rack in both the '00 Regal and '04 GTP is 49.75", while my '02 GTP is showing 48.75", so doesn't look like it will fit for me. Seems to me they would all be the same, GM is known for re-using parts out of the corporate parts bin.
Is there less turning of the wheel because the GXP rack is stronger? Does it maybe provide more hydraulic pressure because it comes from a heavier vehicle? We all know the stock racks are garbage. I wonder how much more durable a GXP rack would be.
I will be doing the rack on my 2000 GTP in the next week or so. I was thinking if I buy the GXP rack on RockAuto, and then ship back my GTP core, will they give me a hard time and say I'm pulling shenanigans? Resulting in me loosing $100. Maybe this is something I can pull off easier at a store at the counter.
if you know what makes a rack work, you'd know its just a different gear ratio used. cant see this .25 of a turn helping much really.
back in the day if you swapped a quick ratio steering box you went from like 5 turns or so to 3.0 ish lock to lock, you had a noticeable difference.
they should be the same the only vehicle I could see having a different rack would be the G & H bodies and those have completely different mounts for the rack.
Double check the part number for the inner and outer tie rod ends and they all seem to cross to the same for me
...... does this mean that I can take my 04 comp g magnasteer rack and put in my 07 non magnasteer plug it in and it will work?
I'm not an expert but from what I have heard on here it should work l, minus obviously you wont have magnasteer.
Sent from my LG-H918 using Tapatalk
