    TIPS:
Stattama Turbo Kit + Custom W2A Intercooler (98-02 Grand Prix)
baddestGTP
attachment.php
attachment.php
*$3250 shipped to contiguous 48 (no longer includes Paypal fees)
* T-67 .68 A/R P-trim ball bearing water cooled turbo
* TiaL BOV (genuine, purchased from ZZP)
* TiaL watercooled wastegate (genuine, purchased from ZZP)
* PTP turbo blanket
* Frozenboost Water to Air Intercooler 600 HP Kit (WAT001006)
* Bosch Cobra intercooler pump
* Custom 97 GP windshield washer/intercooler reservoir
* Custom vacuum distribution block with AN fittings and lines included
* Heater core coolant hoses modified with AN fittings for source/return lines for wastegate
* Thermostat housing drilled/tapped with AN fitting for turbo coolant line
* Smaller Monte Carlo brake booster included
* Original instructions from ZZP included
* 90 pics and 2 videos showing the turbo compressor wheels here: Stattama Turbo Kit - Google Photos
To run this kit, you will need:
* Intercooler pump harness
* Tap LIM for turbo coolant line
* Couple feet of rubber water line hose & joiners to patch a couple areas where I had to cut the hose when uninstalling because I couldn't free the hose from the hose barb due to tight install area
* Kit is configured to work with a L26 UIM/LIM, so if you're using a different intake setup you may have to extend/shorten vacuum line hoses, etc
If I were reinstalling the kit myself, I would also acquire:
* All new rubber water hose lines
* Less complicated water reservoir setup
Other things you may need:
* If you're not running an oil pressure sender, you'll need a new adapter with AN fitting for the turbo oil feed line. I could not separate the Y adapter shown in the pics from the AN fitting included with the kit, but maybe you'll have luck with it.
