    TIPS:
Stattama kit, Built trans, Ported heads, spoilers, Alpine PDX amps+more
I think they designed these engines pretty good for boost, they are pretty much bullet proof hi or low comp.
And who the fck asks the wife for permission you girls need to get your balls back. I told the women I was buying a turbo for the gp years ago, she said if I do she is gone. Its been turbo what 4ish years? And guess who is on the couch to the right of me.........yup STILL there!
SO mu ch to upgrade? Bolt the thing on and go boosting, dont run 20 psi on a stock trans and you should be crusing for a while, my pump was going out on the trans only reason I beefed it up.
Does the spring isolators include front upper & lower? Include the rear lower as well?
Strut mounts and bearings for the front or just mounts?
Interested.
Yes whole shabang. Front upper and lowers, rear lowers. All four mounts, and the fronts have bearings. HOWEVER. It's looking like I MIGHT keep them and get some dirt cheap struts to put on the car and drive it.
Buy a $5 roll of heavy duty bubble wrap and some 3M packaging tape - all set
Might work. Got that **** at Walmart?
PurpleGuy, you're just tempting me with the stattama setup here! I might have to piss off the wife by using the tax return on this.... :th_laugh-lol3:
Buy it, you'll love it.
You should, turbos are tons of fun :D
Listen to this guy.
I'm just worried about my trans and how I'm going to deal with the compression ratio of l36 engine without melting a piston! I wish there wasn't so much that needed to be upgraded too :(
Engineers need to design things for turbo in mind! Screw cost saving analysis! I'll let that poor schmuck buy it brand new off the lot and waste his money! Then buy for $200 on Craigslist when it's broken! (Like what I did with my car!) :)
L36 doesn't care. Alex ran his L36 at over 500whp on this setup IIRC. The only thing that really NEEDS upgraded is the trans. It'll make plenty of power with a baby cam, or even a stock cam for that matter, with stock heads and all.
Walmart and one of those dollar stores. The dollar store I know for sure has rolls of 3M packaging tape for $1 vs $5-6 like say at the post office or something.
I ran an l36, it’s better for turbo anyways. Run the l26 uim and do the HD diff upgrade if you haven’t already and keep boost low while you save for a trans. But buy a tuner before you do anything else if you don’t already have one.
Alright, well if you decide not to keep them, I'll take them. Would just need a price shipped to 53718. Paypal ready.
Okay. I'll check it out. Thanks.
Or he could just buy my trans too? Haha
Will do
Intercooler and/or e85 is how you keep from melting pistons with the higher compression.
Sent from my LG-H918 using Tapatalk
I can honestly say I've never heard of someone melting a piston in a 3800. Chipping them sure, but that's usually a tune issue.
My pistons melted after they popped and I had to drive 20 mins home on 3 good pistons lol. The piston pieces were mashed into the valves but didn’t damage them some how.
I popped 3 pistons on the dyno because of too much knock on is3 setup. They popped and then the pieces got mashed up into smaller pieces. The carpet under my center console started smoking because the cat got so hot. I was able to use a wire wheel on the valves to get all the piston pieces off. I though I had a pic of them but I can’t find it.
Bump. Someone buy this stuff. I need a C5...I mean a house. I need a house.
xfdgsfgjgkfghnhkghjkgh
