State College PA Tune?
shawn3091
I need someone that can disable my knock sensor between 2000 and 3000 rpm, I have been having random knock readings that only ever happen in that range. Is there anyone nearby that would be able to help me do that?
You have an aftermarket blower pulley that makes more boost than stock, right? So why do you assume that the knock readings are false?
Maybe the question you should ask is, "Is there anyone nearby that can reduce my WOT spark timing between 2000 and 3000 rpm?"
it will do it with no belt on the supercharger, and what i beleive its picking up is the lifter noise i have at that certain rpm that i cannot get rid of
I see ... I wasn't aware of that. I understand why you want that, but I would feel a little nervous about not having the knock sensor active at those RPMs ... if you get into high boost, low-rpm situations, it could be dangerous.
You might be able to work out a solution like this ... raising the threshold at which the knock sensor kicks in.
Knock Retard
Don't mean to tell you what to do, though. Sorry for the minor derail.
that may work but i have no way of doing it myself, I have a tune from zzp and the only thing i have is a iccu, so i need to find someone that can edit my pcm for this
