1999GTP1999
I have a 1999 GTP with 240,000 kms. About a month ago I was driving home one night, and while I was driving (about 50 km/h) the engine cut off! I tried starting it back up a few times but it would only start for 1 second then die. I knew it wasnt low on fuel, because I recently put 20 litres in, but still decided to put 10 more litres. After 2 or 3 failed attempts to start the car, I decided it was to late and cold to figure this out right now, so I ended up pushing it to a friends house nearby. When I got it to my friends house, I had really high hopes that maybe by some miracle the car with start with one more try, however, the car wouldnt crank at all this time, so I gave up.
2 days later I came back to deal with the car. The first turn of the key and the car started perfectly! I let the car idle for about 5 minutes to see if it would shut off, and it didnt, so I decided to drive it home. 2 minutes away from my driveway it dies again while driving, so I ended up pushing it home.
Since then I've changed the fuel pump, fuel pump resistor, and the fuel filter, by doing so, the problem seemed to have worsened. The car does not crank at all anymore. So I decided to boost it, and it boosted with little to no effort, but when started it idled really rough at first then idled normally, but after letting it run for a while, I turned it off then tried to start it back but it wouldnt crank at all. I boosted it again the next day and it displayed very wierd symptoms, it would idle high then low, back and forth, and the headlights would dim high and low also. I dont think its the battery or the mas air flow sensor because those were changed within the year, but then again anything is possible. Also, I scanned it for any codes, but none came up.
If anyone has any thoughts of what can possibly fix the problem, please let me, it would be greatly appreciated
Thank You
Thank You
