intrigue98
Haven't posted on here in a long time, partly due to purchasing a G8 GT and have been modding that. After having purchased everything to do a big turbo build on the intrigue, I realized that the G8 was going to turn into the show car/weekend driver and the intrigue was going to become the daily driver. That said, I decided not to turbo the intrigue and instead do a Gen V/IC'd build using some of the parts I've already had laying around from my totaled GTP. More pictures to come but thought I'd put a mod list down here so I have for reference too. Heads just got sent to the machine shop yesterday so looking forward to getting them back.
Bill (billboost) has been joking with me since I'm basically doing the old bonneville setup he once had. Maybe it'll convince him enough to mod again once its built, tuned, and dyno numbers/ 1/4 mile times to back it up haha.
Engine:
- L32 stock bottom end (55k miles)
- Rollmaster double roller timing chain (gear machined properly)
- ARP Head Studs
- Heads - ported/polished, stock valves, 130lb springs, CC locks, CC Titanium Retainers
- INTENSE S1X cam
- Yella Terra 1.8 roller rockers
- INTENSE chrome moly pushrods, 7.300" length (to match yella terra's)
- Ported and polished LIM
- Custom IC kit made by IRC fabrication - 2" core, bar and plate heat exchanger, Meziere 20GPM pump, billet reservoir fill/container - 2.5 gallon closed loop system
- Gen V - not ported, MPS, 2.9" pulley
- N* TB + adapter plate
- 4" intake + cone
- PRJ wires
- Meziere electric water pump
Transmission:
- Precision reman stock convertor
- 7/8" chain w/ 2.93 gears
- ZZP Chrome moly pump shaft
- Desert Fox trans cooler
- INTENSE 300M input shaft
- Triple Edge Valve Body and channel plate w/ upgrades
- Transgo Shift Kit
- 3rd gear Z-pak
- Raybestos blue plate frictions
- ZZP aluminum trans pan
Exhaust:
- SLP style headers, hi-flow cat
- Borla Catback
Fueling:
- PRJ pump + re-wire
- 42lb green top injectors (may upgrade to LS9 injectors depending on fueling)
- PRJ fuel rails
Tuning:
- This should be the fun part. I have DHP and HPT but since I've gotten used to the HPT interface I'll want to use it. However, HPT currently does not support my Olds Intrigue. That said, I'm going to try and make the intrigue a 1998 GTP via VIN and BIN. Hoping this will work. If anyone can offer insight its appreciated. Thanks in advance.
And for those who have never seen the intrigue, here is what it looks like currently:
Engine:
- ARP Head Studs
- INTENSE S1X cam
- 4" intake + cone
- PRJ wires
Transmission:
- Transgo Shift Kit
- 3rd gear Z-pak
Exhaust:
- Borla Catback
Fueling:
- PRJ fuel rails
Tuning:
