Starting problems
SCGTP
I will try this one more time.
For about a week now when I try to start my 99 GTP I get a clicking sound from behind the dash and the car does not start. This sound only happens when I turn the key. The clicking sounds like it is coming from the passenger side behind the dash. The car starts perfect when I use the remote starter. The car has 83000 miles on it. Any ideas what might be causing this?
It was suggested that I swap the relay to see if that was the issue. I did this and the car is starting with the key now. It still worked when I put the original relay back in.
I wanted to check some of the less expensive fixes before the ICM.
Now that the car is starting any other ideas what might be causing this?
