Starter Location on a '92 w/3.4l motor
eight4u
i feel kinda stupid guys,but can anyone tell me where the starter is located on a 1992 SE with the 3.4l DOHC motor?I've looked all over the engine compartment as much as I can and can't see it. might help if I knew exactly where to look. thanks.
You can only "see" the starter from underneath. It is on the front of the engine and partially hidden by the subframe when you peek up through. Not a fun one to change, but still possible without removing a bunch of stuff.
Thanks for the info.I don't need to change it,just wanna check the battery cables to make sure they are tight.The car doesn't want to start or even crank,all it does is "click" when i try to start it.I just changed the fuel pump and went to start it and it turned over a few times,then just the click sound.so hoping it's just a cable problem,i had it on jack stands when i cranked it at first,but don't think that would cause a problem.I'll let you know how it goes.again,thanks.
