Stage 2 axles?
glanzergtx
Are these axles worth it? I am going to be running a 3250 stall with DR's at the track with a full built trans. Will stock axles hold up? Or should i invest in the some upgraded axles?
https://www.zzperformance.com/grand_prix/products1.php?id=858&catid=105
The mods will be as follow
CAM will be XP or bigger will be a winter project
-ported inlet outlet s/c
-ported LIM
-ported heads
- MPS 3.0
-65# injectors for e85
-Built trans with 3.29 gears 300mm input with 3250 stall
-Drag radials
-55 dry shot nitrous
-Wizaird
-1.9 rockers
-TOGS
-ported 97 TB
-105# springs and retainers
the axles on this car need to be replaced already. But is it worth the money for stage 2 axles if i dont need them?
stock axles are physically about the same strength. the good part about the stage 2 axles is that they have grease ports on them so you can actually regrease them when need be.
so for 300 bucks i get greasable axles whoohooo :th_angry2:
