if I am sitting at a complete stop on a flat lot then take my foot off the brake as the car starts to creep forward it starts to squeal almost like a rubbing noise the pitch will change lower as it stops and higher as it gets from 1 MPH to 2 MPH after 2 MPH it's silent or at least I can't hear it...
car was realigned, nothing changed...
car had ball joints changed, nothing changed...
new brakes, nothing changed...
tires have the correct air pressure for the car (30 PSI according to the door sticker)
is this a sign of a bad wheel hub? or something else?
no steering noise causing this, the car is doing this going perfectly straight when this happens...
the noise is only loud enough to hear if I have the window down, it's coming probably from the front drivers side from the sound of it..... roll the windows up I can barely hear the noise inside, but you definitely can outside
this is a 2008 base GP
