squeaks over every bump
twoleos617
I got 82k mi on the original suspension. I get squeaks out of every corner when going over bumps. I've been to the quick lube places but they tell me there's no lube points on these cars. Is this right?
I get these squeaks on both compression and rebound...quite annoying.
any suggestions??
I had a squeak in the rear of my 02 it has 40K turns out it was the exhaust hangers on the right muffler were hitting the hangers that are on the body causing the squeak and not any suspension issues dossent sound like thats your prob but its worth checking and i dont believe there are any lube points but i may be wrong good luck tho
Id would also say struts. Just give each corner of the car a bounce just by leaning on it to pinpoint the noise. Also pull the boots up off the shock inside the coil (if there is any) and see if there is any oil leaking from the shock portion of the strut assembly. If it does turn out the be the struts always replace then in either two's or four's. Fronts, rears, or all of them.
If the noise is up front you could also have a worn out or dry ball joint or tie rod end. hope this helps
