Spyder Auto HIDS
bonerjamz03
I have a quick question for anyone who has installed these. Is the bracket from the stock headlight needed for installation of the new headlight or can they just be installed right out of the box without the bracket?
Are you asking because you don't have your stock headlights? The wiring harness that connects the turn signals needs to be switched over from the stock headlight.
No I still have the headlight but the bracket is all busted up. The only reason I'm asking is because I emailed spyder auto before i bought them and they said i had to use the bracket from the stock headlight. I just got them and it doesnt seem like i need it so i just wanted to double check.
Just be careful not to break the bracket on the projectors. They can not be replaced and you can not use your facotry brackets with them.
