    TIPS:
Spring clean out sale! HV3, N*, fuel rails, trans, and more!
SnowFlake
Banned
All parts in CT, add shipping and fees!
N* TB w/ bracket, LS1 MAF, and GenV adapter plate $150 (perfect if doing GenV swap SOLD
HV3 for L26 (works in L36 as well) $150 SOLD
L26 upper/ported lower manifold, injector ports and PCV plugged for turbo. $100
ZZP modded fuel rails, to clear for intercoolers or turbo setups. $100 SOLD
Comp cams 105# springs, good batch... MAYBE 10k on them. $70 SOLD
High-Flo 255lph fuel pump, almost brand new. $40 SOLD
Stock rockers, $20
L67 Harmonic Balancer, $40
Regal Taillights, in good shape. $40
Local Pickup Only Connecticut - Limited time! This stuff is going to the scrapyard SOON
4 stock Regal Chrome wheels with next to brand new summer tires. I can't be 100% sure that some of the wheels don't leak. But you can get bead sealant to help. $300
4 stock Regal Chrome wheels with bad tires. I can't be 100% sure that some of the wheels don't leak. $100
Stock trans from a 97 s/c Regal, 100k, drove fine, perfect for a stock replacement in a pinch or core for rebuild. Needs a harness plug ($60 from zzp) $150
3 stock steel subframes $20 each
did the pcv valve leak too much under boost? on the l26 manifold. where did you move it too?
thanks
