Special Edition Valance
onklp
Hello Guys
I have some question who installed SE Valance extension to their car 04+ did you cut some holes in the bumper for the tabs what are on the new extension ?
Front or rear?
For the front one all I did was use a razor to remove 4 tabs on valance that had no where to go on a non-se bumper.
Then it reuses the screws on the bottom of the side, and the pop pins in the front.
It is a little longer than the bumper in the wheel well so if you want to secure it there you'll need a spacer and drill a new hole in the wheel well.
Hi to the front one if you look at the radius there is two tabs on each corner pointing on 45 degrees in the fog lap area
