First off, get yourself a new set of wires as well as they are likely to break/separate when you remove them thus rendering them junk.
Also, twist the boot on the plug before removing them as it will break the boot loose from the ceramic and make removal easier. Watch your hands on the front 3 as when they pop off the back of your hand/wrist has a nice way of finding the fan shroud which is sharp :th_winking:
ONLY DO 1 WIRE and 1 PLUG AT A TIME. This will reduce the risk of crossing wires. Trust me it happens all the time, even when you swear 3 times over that you didn't.
Get some dielectric grease. A small tube will do.
The front 3 are straight forward. Just grab a spark plug socket and a 3' extension and go to town. Put some dielectric grease on the inside of the boot where it connects to the plug and on the other where it attahces to the coil. Reuse the stock heat sheilds on the plug end if yours has them.
As for getting to the back 3, since you're new at this your best bet is to remove BOTH front dogbone mounts and then attach a ratchet strap to the hook on the motor and the other end to the rad. support. Then just rock the motor forward a bit using the strap to hold it. It will only rotate a few inches but with the worn motor and trans. mounts your car probabaly has it may move a bit further. Just be aware that the front exhaust manifold may hit things up front, and that the rear exhaust can only flex so far.
From there its just follow the wire. The rear plug closest to the drivers side is almost in line w/ the O2 sensor, so be careful. Same as front use dielectric grease and heat sheilds.
Make sure you get a nice "click" as you connect the new wires to the spark plug. If not, then double-check that it is on securely.
Once you get all the rear wires in place make sure NONE of them are touching the manifold or the 02 sensor as it will burn the wires and cause issues. Use zip ties if you must to keep them out of the way. There will be some slack in the rear 3 as most replacements are longer than needed.
I personally would just go w/ stock Delco wires and a good copper plug. I run NGK TR55 V-power coppers in my 00 GT and it runs just fine. Check the gap on the new plugs and make sure its set properly (should be .55 IIRC).
Fire it up and enjoy a nice smooth running vehicle
