2005 GTP, and the only mod so far is the CAI
With that said. I'm trying to figure out the best plugs to get. I have done research, but I still can't seem to come up with the correct answer. I just hit 96K miles, and I still have the stock plugs/wires, and I'm thinking it's time to change them.
If I look at auto part stores, they say Autolite 606's ONLY. Anything else is flagged as "Will not fit your car". I've seen message boards where the 605's would be fine as well. But if I get the 605's, is there anything that I need to do with them? Is the gap fine on the 605's?
Wire recommendations?
One last thing....If I ratchet the engine forward, where is the best place to hook the ends? I've seen someone use the alternator bracket at one end, and the other end close to the hood release. And I've seen someone use the motor lift mount on one end, and take the other end over the front bumper, and somewhere underneath the car.
Thanks,
Jeff
Thanks,
Jeff
