TurboKent
Was wanting to know what the chances are that a spark plug with a small gap of .40 could collapse on itself? I've been running Autolite 103r's with my turbo setup and when driving the other day my service engine light started flashing so i pull over and the engine is running rough but still running. I baby it the 4 miles home connect my scanner and read the codes. Main issue was engine misfire. so I start to take out the plugs and check the wires. The back three were fine but cylinder 3 when i pulled it out it was collapsed to the point of the electrodes touching. After looking at the plug closer it doesn't appear that it was force that way by any physical object hitting it(valve, or piston) because there are not any scuff marks on it. So what are the chances of it doing that due to boost what should i be looking for?
I'm going to try putting in a new plug and starting the engine to see if it still has any problems here in the next day or two.
