sparkydog
2 weeks ago I replaced my steering rack and while doing that I noticed I had a lot of oil on and around the oil pressure sensor just above the oil filter. The sensor, the connector, the area below the sensor and the area above the sensor were coated with oil. Given that information, I decided that it was either the sensor leaking and then air currents spraying the leak all over everything, or - it was a leak up above the sensor coming down the side of the block. But it is very hard to access this area or see into that area. I felt the rear valve cover seal all along the back and it is dry (or as dry as it gets). I'm pretty sure I upgraded the valve cover gaskets a few years ago. The car has about 160k miles.
So at the time I chose to hope that it was the sensor leaking and I replaced the sensor, cleaned off the excess oil as best I could and finished my steering rack job.
After driving for a few days I've still got oil leaking so I must assume it is coming from above the sensor area. I think that means either the head gasket or the valve cover gasket, right??
Any other ideas where it could be coming from? Thanks!
