some cam info for thought *possible sticky*
joshv
**possible sticky****
met up with will overkill for burgers and tuning ( a friends car ) and we talked about cams
just in case anyone didn't know any 2005-2006 LS4 can use a LS9 cam
P/N 12638427.
the 2005-06 ls4's use 3 bolt cam gear which the ls9 cam is.
the 2007+ is you use this part P/N 12586481 it will give you a 3 bolt came gear- or a ls3 cam is a single bolt cam
in the 07+ ls4's use the Ls3 tensioner which has been proven less durable then the older ls2 style that the 05-06 ls4 use's. its not recomended to swith with newer ls4s but is an inexpensive part if you wanted to
ls3/ls9 valve spring kit P/N 12499224
Nice little tid bit of info, Will knows his stuff.
As soon as I figure out the best way to yank this LS4 out of this car, I'll probably be doing a cam swap over the winter.
Pretty sure I'll be that guy and use a BTS3/4 cam in this thing. Uselessly huge cam for maximum noise.
blueguy you pulling engine just to install cam ? can be done through wheel well aswell
and yes will is a very interesting guy!
I should revive that LS4 overall mod thread that I started a couple years back.
And Josh I'm not sure. I've got a buddy who's a huge LS guy with a built catfish...and he's done quite a few cam installs...plus he has a lift so I'm assuming we're just gonna lift the body off the powertrain.
