some advice on my mods?
David99GTP
I had my water pump go, so since I have to tear into the car I decided to get an electric water pump, a smaller pulley and I also decided to install a set of SLP headers. Will I be ok putting a 3.4 pulley on the car without getting KR?
Thanks in advance!!
I already have a Borla exhaust, CAI, DHP PCM, Gen III fuel rails, 42.5lb injectors, upgraded wires and coil packs on the car.
Typically you would be ok. You need to keep this in mind though.
NO ONE CAN TELL YOU IF YOU WILL BE OK OR WILL HAVE NO KR WITHOUT SCANNING.
To be honest I would try and find a cheap used DHP power tuner. That way you can scan and tune. And it's just about as much as a scan gauge alone.
