Solenoid question
rryanwswan69
Alright guys so my code was shift solenoid b stuck on. What would you recommend doing? Just replacing the shift solenoids? Also here is how I got this I was driving and stopped at a light went to go and nothing. Pushed the car to the side of the road and after awhile of turning car on and off got it to work. So took it home. Next day went to try to pull the car out of the garage and same thing and thats when i read the code. Any input would help. I already have the side cover taken off.
I'd pull the solenoid, IIRC B is the one to the rear of the car and see if the valve is moving with my little finger. (aka stick finger in hole and play around with valve). Check the wiring for continutity and look for any pinched areas. Replace solenoids and pray a little.
