    TIPS:
Solddddd
Re: 6 NEW 42lbs EV1 Injectors
Lucas:
  • Coil Resistance: 15.8 Ohms / High Impedance
  • Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 440 cc/min = 42 lb/hr
  • Dynamic Flow @ 2.5ms PW @ 100Hz: 16.88 mg/pulse +/-10% @ 2.5ms PW @ 100Hz
  • Spray Patter: Tri-Cone
  • Physical Dimensions: EV1 Body Type
  • Connector: Bosch EV1
BWD Green tops:
Body: Metal & Composite plastic factory fitted with Viton upper & lower O-rings.
Resistance: 14.5 ohms
Flow Rate in LB per hour: 42 LBS/HR at 43.5 PSI
Flow Rate in CC per minute: 440 CC/min at 43.5 PSI
Pressure: Min 30 PSIG / Max 100 PSIG
Voltage: 8-15 Volts, nominal 13.5 Volts
Amperage: 1.0 Amps
Length: 3 inches, 74 mm
Diameter: 24 mm
O-rings: on both Top and bottom about 14.5 mm
Lucas:
BWD Green tops:
Amperage: 1.0 Amps
Diameter: 24 mm
They are really close huh?
