Can anyone tell me what is most likely causing this? It only leaves a small amount of liquid on the ground after every drive. https://vid.me/RI1Y thanks in advance
if the fender is dry id think the water pump took a dump, it leaks out a weep hole on the back bottom of the pump.
car off, with two hands grab the wp pulley, push with one hand, pull with the other then see if it rocks a little bit, if it moves, you need a new pump.
you can also use a mirror on a stick to see if its wet under the pump.
you also might notice a strip of fluid on your hood that lines up with the belts, thats a water pump as well.
