Signal Flasher, Where Are You?
MyHero
Google Images is giving some wonky results, is it toward the top of the brake pedal?
Got LED tails and a few in the crappy FleaBay headlights and the stock flasher freaked out. Got one rated for LEDs but not sure exactly where it is.
I Took the column cover off because someone on FB told me it was right under the switch for the hazards. I think I got trolled on that, which prompted the Google Image search.
Thanks in advance y'all.
theres two relays in my car under the dash to the far left near the door side of the dash. ones the abs relay, not sure wtf the other one is.
i do have a regal but its work a look. if i take the side cover off for the dash there, i can see it.
You beat me to it. LOL
so you understand, the flasher is screwed, or clipped, i forget, to the dash there. unplug it then see if the plug will fit what you have in hand.
This is it- I was thinking of a barrel shaped one for one of my other cars, my bad.
Haven't had the chance to put it in yet, ah, life with a toddler in your face constantly :D
