Hey Bill,
I was looking at your write up here: http://www.grandprixforums.net/how-transmission-4th-gear-side-cover-access-54448.html.
I am going to pull the side cover off the recent rebuild because I am beginning to suspect VB or CP gasket leakage as the cause of the problems I'm having. I noticed that you support the engine from above, but doesn't that prevent the engine/tranny assembly from coming down? Does lowering the entire assembly affect the top motor mount or exhaust piping? Do the tranny cooler lines need to be disconnected? Sorry for all the questions, but I really need to get this dang thing fixed as soon as possible. I'm ordering new VB and CP gaskets from TEP today.
Also, here is a rundown of the problems I'm experiencing, maybe someone has a suggestion:
Normal town driving seems fine. 1-2, 2-3 shifts feel fine. Occassionally, when pulling a steep hill from a low speed (maybe 2nd gear) it doesn't want to downshift...kind of hard to describe actually, but it doesn't feel right. Also, hard acceleration will sometimes cause a mis-shift/delayed shift 1-2, sometimes 2-3.
On the interstate is where a big problem was discovered. Last week I took it out on the highway and all seemed fine. A couple of days ago I took it out again and bingo, something is wrong. At cruising speed (65mph) all is good, rpm's are 1750 and it's smooth sailing. As soon as I start to take even the smallest hill, it seems like the TCC unlocks, but there is no power, the engine just revs. As soon as the car slows to approx 47mph, I can feel a gear engage (maybe 3rd?) and speed back up to cruising speed again. The same thing happens if I am cruising along (again, highway speeds 65mph) and suddenly let off the gas: TCC unlock, but it's not in gear.
I have reason to believe the torque wrench I used is not reliable, so I may have the leakage I described. In any event, I have to believe the problem lies somewhere in the VB/CP area, since that is the common denominator to these problems considering the only time they occur is under load.
If anyone has any ideas, I am all ears. We have been without our DD for 2 months now.
Thanks.
Thanks.
