Hi everybody
This is my first post on here so bear with me. I've been having an issue with my car shaking like crazy at high speeds. Originally I thought it was the CV joints, but it also occured at slower speeds after going faster and not just under load, and I didn't get the characteristic clunking on slow tight corners. I've noticed that the front drivers wheel seems to have alot of dust clinging to it so this morning when I got out I felt around the rotors, and the front drivers one was radiating heat, like alot of heat, while the other ones were hot, but not overly. I was just wondering if this points to a seized caliper? I did my own brakes for the first time in the summer, and it ran fine after that. My parking brake did stick after releasing after the brake job, but I believe that it is only on the rear wheels so shouldn't cause this on my front. Could I have done something wrong when I changed the brakes out. I didn't change the rotors (I'm cheap and they looked ok), could it be a warped rotor. The thing is, it doesn't do it all the time, mostly just in the first 20 minutes of driving or so, guessing once it gets hot enough it either evens itself out, or it's so hot that braking performance is reduced to the point that it doesn't cause the shaking. If it isn't a warped rotor, is it likely warped now? I'm kinda tight on cash, and only planning on running this car for another few months or so, so not looking to fix everything for the long term. Just looking for advice from the pro's on what they might think is wrong and what I can do to fix it?
Oh, and I forgot to mention that shortly befor all this started hapenning I had the front passenger strut replaced, and no alignment was done as they checked it and it was still all good. Could this be caused by an alignment issue?
