crzystve42
Can I drop a series 3 into a car with a series 2 transmission? Does it have the same bolt pattern?
3800 = 3800?
You just have to know which block you have. Not that is matter for a swap, but for what mods you may run.
Yes, 3800 block.
He means N/A or S/C.
Yes, 3800 block. Its in regards to dropping a series 3 into a firebird 5 speed and I feel that if they are the same 3800 with the same bolt pattern that the series 3 should fit onto a 5 speed firebird
it doesn't matter which you have a 3800 block is all the same whether if its s/c or not, but if you have an engine in mind and the trans just happens to be a 4t65-e HD then your all good to go
