Series 3 to series 2
94grandprix
I found a 04 grand prix with a 3.8 na that dosent run,my 98 is gonna cost well over 650 bucks to get it nice,the 04 is only 650 bucks,what do I need to do to put my 98 3.8 sc engine and trans in it?
tranny wont work, but you can install the engine, then get a gen 3 to 5 tb adapter plate and a tuned pcm for the engine swap.
So the pcm out of my 98 won't work? So regardless my trans won't work period? Can't I use the na trans and use the 3.8 torque converter?
its the hook up of cables and plugs, and the way the tranny works in a 04. you would swap the flex plate so the engine fits the na tranny's converter.
the pcm is not he same at all. dont even look the same, nor are the plugs to it the same. 04 up has 3 plugs.
the fuel pump comes on,battery is good,throws code p0036 and will not start but turns over, has fuel pressure,what can it be? ive replaced fuses and relays
Forgot to mention it runs great or did and I started driving and made it 15 miles and it died like motor wise I still had power
