JIMMY PITBULL
Well I put another seal in on the driver side cv axle, and still have a leak at closer inspection I noticed it is coming from the rubber seal that wraps around the axle ,checked the first seal for the spring and it was still there ,checked the second seal also it was still there .After closer inspection of the axle I noticed a small very fine groove around the axle shaft were the seal makes contact, I then replaced the axle ,no more leak . It is truly amazing how the smallest little bit of wear on the axle could cause a leak...So when you go to replace a seal take a good look at the axle itself it will save a bunch of time...
