SD Headers or Plog with 2.5" DP
ImColeTrickle
Can probably get the SD's for around 170-180 with free shipping. Front Plog 149.99 before shipping. Already have 2.5" DP.
What should I do?
depends on what you want really.
headers will move your powerband so you get more high end power, but a plog will let you keep that low end. id go with headers though.
Depends on goals as always. I believe (and someone correct me if I'm wrong) if you ever plan on turboing, you can use the plog where as the sd headers would be useless. If you don't go the turbo route, my opinion would be sd headers as I have them myself. Cheap and gets the job done.
The headers will need different clamps $20 and a different flex ~$50 welded in before you install them
The Plog will need to be removed from the engine after the welds crack.
