SD Grand Prix Front Air Dam, 2000 GP
cboth686
Just wondering if any has this mod, and was it easy to do? I've heard mixed reviews but I really wanna spruce up my fascia, thanks!:th_nanana:
if you have the money, you should do it. the only problem ive heard about it is that you have to mount it using 3m tape, but if that doesnt hold you could always use something else to mount it
the double sided tape is total fail. Only get it if u plan on getting it molded into the bumper
I just put mine on. The 3M tape is worthless. You will have to use some screws to hold it in place. The fit is not the best but it does look nice. The sir dam does not fit flush on the center pillar. I used pine tree fastners for the center part of the air dam to hold it onto the stock center pillar. I also used some screws in the wheel well to hold it in place. Other than the fit not being very good, the look of it is nice when installed.
Its the center pillar. You will have a small line towards the top of it. You won't have a problem with the gaps on the sides inless you mold the kit into the bumper.
You can see it on the PFYC's site cat its just hard to notice inless it is infront of you.
Talk to someone at a good body shop, they will bring in someone from safeauto or similar. Use the same glue that is used on winshields to backfill the spoiler. Once dry the shop will prep and paint. Only downside is you'll never get it off to resell unless you remove the whole bumper and sell it.
Close but, windsheilds are installed using urethane. What they will use is a 2 part epoxy for plastic to plastic bonding. Common brand would be LORD's Fusor.
I used screws in the wheel wells for mine, and one on the bottom underneith to hold it snug, i havent had any problems with fitment or anything, only issues ive seen from others is alignment around the fog light holes, some people have problems getting them to sit perfect around that.
Heres a pic of it on my car.
i like the look of that...im just wondering whether or not it will hold..im kind of getting mixed reviews here..
I've had the SD air dam for several months now & I say its visually worth putting on the car. Big visual improvement. The big problem is bottoming out & that gets worse if you have lowered you GP. Worse still if you live in a bumpy city.
