S/C spacer?
DWosik13
so i was looking into getting a spacer for my s/c but it says the spacer blocks coolant to the s/c from the lim is there any special things that need to be adjusted if i put it on or is it good to go just slap it on and its all good?
You don't need that coolant flow there anyway. It does nothing good anyway.
i have my LIM coolant ports blocked off. you just have to know that those holes help with cooling the rear head. you need to open up the side part of the LIM under that cover so you can compensate the flow youre losing from blocking off the ports.
