Incomudrox
I have never run speaker wire to the doors. What is the best way to do this to get it though the doors? Can i just cut one end and tie the new wires on and pull it through ?? thanks.
Thanks...only reason I am doing this is because I got my headunit in the glove box. Now my right front speaker isn't working. I have ruled out the AMP,RCA's and Headunit as the problem. It's losing connection somewhere. Right now the way i have it is, I have at the harness the front speaker wires hook into the rear speaker wires and i power the front speakers using the rear speaker wires to the AMP because the AMP is in the trunk. Because they where more accessible at the time. If that makes any sense.
woah... hmmm kinda not really heh.... perhaps a diagram would help out... or are you saying youre powering the front speakers from the factory amp in the rear, by using the rear speaker wires?
get some new power wire, that speaker wire can't handle the current the amp will draw, you have a fire waiting to happen there
