Rubbing/grinding
94grandprix
On my 98 gtp when I pull in my driveway which is down hill and I stop at the top I can feel some kind of grinding or metal,seems like it does it when I turn right,what can it be?
Could be the brake pads (front or rear), or the dust shield on the front brakes rubbing. When was the last time you checked all the brake pads? You could also jack the front end up and check for any clean spots on metal under there. If you can hear it then there should be a spot you can see.
I haven't checked them I Bought it a few months ago and had almost new pads,I can feel it in the pedal,I'm putting it on ramps in the morning and investagating
