thomasd2010
car will start but wojnt stay running for more then 30 seconds and when you try and put it in gear it wont go forward or will shut right off. any ideas on what this could be?
Got gas ?
Security related fuel issues are 3-4 seconds. Because the cylinders prime when the key is turned to on, then the injectors do not pulse again.
Determine what you are missing, spark or fuel.
Try unplugged the maf and seeing if you can keep the car running longer.
Pull the IAC and clean it and the bore in the TB.
