Rico
I just purchased a 2002 GTP coupe with 84K. The car is in mint condition except for the motor. At about 4000rpm the motor has a knock somewhere in the rotating assembly. It also appears to have a problem with the LIM gaskets; water in the oil. I plan on replacing the LIM and supercharger gaskets soon. Scanned the PCM - no DTCs
Question:
In the case that the knock is not from a missfire, what kind of rotating assembly repairs can be performed without removing the engine? The knock sounds like a rod bearing or piston slap.
Any comments are greatly appreciated.
...hope I posted this in the correct section :th_nervous:
Question:
