you can clearly see the small dents it creates in tommy gloves' pics....i didnt see these when i first looked at the right up until i did mine and was like wtf are these then i pulled the write back up online and wahlah there they are! this method = epic fail.....it clearly misshapes the fender....the cuts when you bend them up pull the outer fender lip in...
heres what i did to mine
those dents are every place there is cut ....
this is without cutting slits and rolling it as one piece...(the right way) what a diff
...luckily the fender i did with the tg method is dented from an accident, so its going to a body shop ill just have them smooth those divets out.....just trying to save you guys the less fortuante from doing this...look my other fender compared to above !
lots of room to lower now
the rolling your fenders option 1 in the how to section should be deleted in my opinion as you can clearly see the damage it creates in the write up! :th_shakinghead1:
