right struts?
I am not home, so I can't check the part numbers. But check on the KYB website for numbers and Rockauto for prices. Also, better look at your front struts as for 06 or newer, they may have gone back to the older configuration. Look to see if the sway bar connects to the strut or to the lower control arm. If it connects to control arm then it uses the strut for 03 and earlier.
Other things to replace are the top mounts, spring isolators and the bellows covers.
